We have a plate of 120mm X 90mm X 1.6mm aluminum plate with four holes at the corner. We have performed a modal analysis and conducted a test. But, we are not able to correlate with the test result.
The frequency in test is 420Hz whereas in analysis we are getting 300Hz. what modifications can we do in analysis?.Appreciate your help and suggestions.
Thank you in advance.
