I have a strange problem with the deformation of a pipe elemten under bending and torsion moments. I completely constrain the base of the pipe with RBE2 elements in every DOF and on the other side of the pipe I apply the moments with RBE3 elements.
I would expect the pipe to bend down for the bending moment and to twist around its z-axis for the torison. This is the case, but additionally I get a deformation of the end piece of the pipe.
The analysis results in an oval shape for the bending and an extremely widened end for torsion (please see pictures for reference).
I would not expect this with RBE3 elements. I also checked with RBE2 elements and get almost the same result.
What am I doing wrong?
Thanks for your help!
