TH error
I have received a error no restart files.
ALso I receive the TH error in the manual which is there it states time history and there are some input variables.
Could you explain what it means and by inputing the variables what happens ?
Also in the reference manual there are global variable defined for the TH. So suppose I wish to see a plot if that particular variables then is it for the visualization of that?
When I also put in the global variable, it shows error 'TH VARIABLE IE IS NOT AVAILABLE' I just kept a card for internal energy.
Hi Kartik,
Please try with the model file attached.
By inputting the variable we are requesting for output. If you keep DEF in the variable, all the default outputs will be extracted.
0 -
So why doesn't IE Work? It is also a defined variable for internal energy?
0 -
Altair Forum User said:
Hi Kartik,
What are these Radioss Plots that are present? In the model file given by you.
0 -
