      I would like to use periodicities for a toroidal core in Flux3D transient magnetics (12.3). I have set up a simple example with a non-linear steel core and a non-meshed coil. The periodicity is set to cyclic conditions but somehow the magnetic flux won’t concentrate in the steel region.
      I tried the full model with the same geometry and it looks fine, the flux is concentrated inside the steel region. So there must be a problem with the boundary or the periodicity.
      How do I have to set up the boundaries/periodicities/formulations to get to correct results?
      Thanks in advance.
    Best regards
    Patrick
