Hello! Is there any way to achieve the simulation of Doppler frequency shift when moving along a specified trajectory at a specified speed
You may want to look at example D3 in the installation directory. The path would be something like
C:\Program Files\Altair\2021.1\help\winprop\examples\ExampleGuide_models
depending on the WinProp version and on your choice of installation directory.
The example is time-variant, so objects are moving, as defined in WallMan. No trajectory has been defined in ProMan. Instead, the transmitter antenna and the prediction point (the receiver) are moving with a selected object.
Possibilities to define movement along trajectories in ProMan have recently been enhanced, but I'm not sure which situations offer Doppler shift as output.
