Altair RISE
Nominate Yourself Now!
Error #369
User: "Altair Forum User"
Updated by Altair Forum User
Hello Forum,
Im from the Hawks Racing Team in Hamburg and i have some problems with a special error in Optistruct.
I created my Model on my laptop and switched to a stationary computer to do the simulations for our racecar.
On both Stations a check run was done and no errors occured.
As i started the analysis/optimisation on my laptop everything was fine but it took to much time..
When i start the same optimisation on my stationary maschine i get the error #369.
See Picture 1
My Inertia Relief Constraints are able to see on picture 2
I checked so far all Loadsteps
- changed the position of the inertia relief constraints
-did a element cleanup
-did a new definition of plys..
-I deleted the Element with the id 1095447
and the problem is that for that error there is no solution on the internet.
Maybe this forum can help me.
I copied the whole Modell folder from my laptop to the stationary maschine
The problems has to be in the settings of windows or hypermesh
Has anybody a idea ?
Greetings
1 - 3 of 31
    OP
    Maybe some more input:
    ITERATION   0
     *** ERROR # 369 ***
     Auto-spc dof has non-zero mass/inertia.
     Degree of freedom  = 4.
     Grid Point ID      = 1095447.
     Mass/Inertia value = 2.0759e-006.
     When this happens, inertia relief force calculation is incorrect.
     The corresponding static solution is erroneous with
     nonzero SPC forces at the SUPORT dofs.
     This error occurs in module 'lstatdrv'.
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Could you share us  out file or Fem file?
    Do you have superelements in your model ?
    Share us system & update information.
    Regards
    Rahul R
    OP
    Hey Rahul,
    Please find .fem file and out file attached
    As far as im awared I used no superelements in my model..
    Im looking to hear from you
