Good morning
I have a problem with the solver.
The problem is that it does not appear nothing in the solver, after checking the elements it says 'job completed', as you can see in the following picture.
I attach you the file.
Regards
Hi @f.garcia
Hi Palash,
Please try the below:
Close HyperWorks application(s) and Please delete setting files on your machine and try again. Follow the link below on how to delete setting files:
http://forum.altairh...iles/?hl=delete
Also, delete .Altair folder in temporary directory. Go to Run and type
in %Temp% and click OK.
I have done it and I continue with the same problem.
Could be any other posible solution?
I am not using student edition. I am using professional edition, I do not know if it is useful for you.
We have forwarded your query to France support.
Please note: If you are a commercial customer, you can also contact your local support @ http://www.altairhyp...ortProduct.aspx
