When creating a polynurbs object is OK to have 'T - junctions' and 3 sided faces, or should you try to avoid these to maintain a smooth surface once you nurbify?
We do allow all of these types of conditions, but as you said, you may create some issues with surface continuity, so it is best to avoid those wherever possible.
Thanks,
