Impact analysis of a composite tube
Altair Forum User
Altair Forum User
edited November 2020 in Community Q&A
I wish to do an impact analysis of the CRPF tube, I was just not able to understand how to do it in RADIOSS.
I have used Hypermesh - Optistruct and I know about properties like PCOMP, PCOMPP. But I'm not sure what model setup should I use in RADIOSS.
  • Altair Forum User
    Altair Forum User
    edited July 2018
    Similar to PCOMPP there is PROP type 17 and 19 for stack and ply, in RADIOSS.
    Please check the same if you want to use ply based modeling in RADIOSS.
  • Altair Forum User
    Altair Forum User
    Hello Prakash
    Thank you so much for helping me out
    I have modeled, but I'm getting this message and the solver is getting terminated
    Can you please help me ??
    I'm attaching .rad file and error text
    Thank you in advance!!!
  • Altair Forum User
    Altair Forum User
    edited July 2018
    Please assign PART card image to all components and also provide property and material to components.
  • Altair Forum User
    Altair Forum User
    Hello, Prakash,
    the error was resolved successfully, but another error popped up
    I think I'm messing up with the engine files, I have attached the error and my RAD FILE
    Can you please help me further??
  • Altair Forum User
    Altair Forum User
    edited July 2018
    HI,
    The RADIOSS FAQ has the following information about that error.
    What is the meaning of: 'Infinite domain detected'?
    This message can be written by RADIOSS Engine.
    Such an error message may appear during sorting of contact interfaces when the distance between some nodes of the model becomes infinite.
    One has to look at the model behavior to understand why some node coordinates are infinite. One common explanation is 'flying' nodes after the failure of elements belonging to interface surfaces.
    You may have to play with the velocity and also check the material properties of the tube.
