Hello
I have made a lattice optimization. Now I would like to measure the diameter of the lattice beams.
Do you know how to measure them?
I thank you in advance for your help!
<filename>_lattice.fem should have details about diameter (beam). You can edit the deck in any textpad to get the details.
Here are two extracts from the <filename>_lattice.fem:
CBEAM 12983 6184 7674 37285 1.25373 2.25 1.75
PBEAML 2 1 ROD + .1790678 0.0 1.0.1790678
What column stands for the diameter?
Thank you for your help!!
It is PBEAML.
You can also see the dimensions in HyperMesh>> Entity Editor. Here is a sample image of the same
Thank you very much!!
