Non linear analysis using optistruct
Hello folks,
I am doing geometric non linear static analysis on a structure and got stuck into some elemental problems
under the material section,
material - matx02
some parameters are given such as
A- plastic yield stress
B - plastic hardening parameter
n - plastic hardening coefficient
C - strain rate coeff.
EPSmax. max possible stress
my questions (for titanium ti6al4v)
1. value of A: as per wiki it should be in 90-130 MPa but when I saw some papers value for yield stress was >900MPa
2. B- nothing got from google. what it actually signifies in reality. Please explain.
3. EPSMAX: does its value should be ultimate tensile stress.
is there any website available where one can find the values of any material( specially - ti6al4v) in exactly these parameters?
Has anyone got a research article or paper regarding this topic: 'Geometric Non linear compressive analysis of Ti alloy using optistruct'
Thanks n regards
Hi @Ashu
I would suggest to get in touch with any supplier or refer to material supplier manual for material properties for a specific grade.
EpsMax is the failure plastic strain and when plastic strain reaches this value or over it, elements are deleted.
