Running from AcuConsole, AcuMeshSim generates the following message in Error Window:
Traceback (most recent call last):
File 'pnlWin.py', line 944, in funcTool
File 'pnlTools.py', line 244, in toolGenMesh
File 'pnlToolsAcuMeshSim.py', line 120, in __init__
File 'pnlToolsAcuMeshSim.py', line 463, in genMesh
File 'pnlToolsAcuMeshSim.py', line 576, in exportAmsFile
File 'pnlAmsExport.py', line 120, in exportFile
File 'GlobalMeshAttributes.py', line 244, in cmdOutGlobalMeshAttributes
File 'pnlScope.py', line 775, in <lambda>
File 'pnlAmsExport.py', line 719, in outWriteCadInfo
pnlAmsExportError: 'Error from ams export module: <Unable to retrieve cad data> '
In the working folder, __cad_dir.zip is created instead if a CAD.DIR folder containing the Parasolid file that AcuMeshSim requires. The __cad_dir.zip is not a readable .zip file.
No mesh is generated for the model data base. I haven't found the python script file 'pnlAmsExport.py' to see what it's doing.
