Pressure output
Altair Forum User
Altair Forum User
I am using Hypermesh for a short time.
I would like to know how to visualise pressure as an output in Hyperview. Using Hyperview, I can now see the displacement of my model and would like to see the pressure also.
In Optisctruct, I have created a controlcard and selected Outputs, then Pressure.
When I run Hypermesh, import the .h3d file and choose de contour, I can still select displacement but not pressure.
Could you help me please ? Do I have something else to create or select ?
Thank you
  • Simon Križnik
    Simon Križnik Altair Community Member
    edited October 2020
    Hi Laure,
    assuming you are referring to contact pressure output: it is not supported in linear static analysis.
    Please search the forum for queries first, if they are already treated as in this case:
    https://community.altair.com/community?id=community_question&sys_id=bb76483a1b2bd0908017dc61ec4bcba9
  • Altair Forum User
    Altair Forum User
    edited October 2018
    Thank you for your answer.
    In fact I only have 1 body, so I don't have any contact.
    I have used PSCD loads to apply a displacement at some points of the component.
     Is it possible to see in Hyperview the pressure corresponding to the applied displacement (instead of seeing the displacement corresponding to the applied pressures) ?
  • tinh
    tinh Altair Community Member
    edited October 2018
    Hi
    Could you try activating SPCF and OLOAD in control card GLOBAL OUTPUT REQUEST?
    I think SPCD will be converted to OLOAD
  • Altair Forum User
    Altair Forum User
    edited October 2018
    You can also try ELFORCE, which is available for shell and other 1D elements.
    The output on shell element is force/unit length
  • Altair Forum User
    Altair Forum User
    edited October 2018
    Thank you for your help.
    I activated SPCF and OLOAD in control card Global Output Request.
    I now have this types of result in Hyperview :
    Here are the SPCDs I applied on the model in Optistruct, the displacement and the SPCF Forces.
    As the biggest SPCDs are in the right side, the biggest displacement is also on the right side. Is it normal that there is no SPDF Froces on the right ?
    I am not sure that it shows what I want to see : the pressures that would deform the component (make the displacement that I constrained with the SPCD).<?xml version="1.0" encoding="UTF-8"?>Optistruct.thumb.JPG.ad25d93eae6a41d1138f1ef5e28a2e2e.JPG<?xml version="1.0" encoding="UTF-8"?>Displacement.thumb.JPG.271a8691c59e258018159f6abd977484.JPG<?xml version="1.0" encoding="UTF-8"?>1404163307_SPCFFORCES.thumb.JPG.1c401d910b1f6b460f527e01327f1531.JPG
  • tinh
    edited October 2018
    Could you show OLOAD (applied forces)?
  • Altair Forum User
    Altair Forum User
    edited October 2018
    Hi @tinh
    Since the applied load is an enforced displacement, the applied load will show as zero with OLOAD.
    @Laure
    Can you try ELFORCE and check if that helps?
  • Altair Forum User
    Altair Forum User
    edited October 2018
    Hi
    Right, the applied load are shown as zero with OLAOD (applied forces).
    With ELFORCE, it doesn't change anything (don't have any more 'result types' in HyperView).
  • Altair Forum User
    Altair Forum User
    edited October 2018
    Hi
    OK, that's because you have solid elements and ELFORCE are not available for solid elements. I will check if there is any workaround for the same.
  • tinh
    edited October 2018
    Hi @tinh
    @Laure
    Yes, I understand.
    in equations K.U=F , after set zero terms of F at SPC,SPCD dofs, optistruct will output F as OLOAD
    so I think output SPCF data are OK
    ELFORCE is internal force, I think it's not current @Laure 's concern
  • tinh
    edited October 2018
    <?xml version="1.0" encoding="UTF-8"?>Capture.JPG.05f688b5b5a1b1067313f4afbe633ec8.JPG
    It looks abnormal, but I think you should activate GPFORCE in GLOBAL OUTPUT REQUEST
    because above forces are only at SPCD nodes
    after applying SPCD, matrix K will be Kmod and vector F will be Fmod
    I think GPFORCE may represent Fmod
  • Altair Forum User
    Altair Forum User
    edited October 2018
    Yes, I understand.
    Agree, but it can be approximated.
