bird strike post-process
what type of load is it?
0 -
Yeah, I noticed it. Let me check on a sample model and I will get back to you.
0 -
Centrifugal is a physical phenomenon,
Is there a reason you want to counter this?
0 -
yes for 2 reason first of all the centrifugal forces change the geometry of the blade (not realistic effect) after that the stress and strain due to CF obscure the stress and strain due to bird impact. do you know how can i see the effect of bird strike clearly ?
0 -
Hi Nicola,
Yes, it is a physical phenomenon.
You can review the results of the bird alone. In contour select only bird component contour for it alone.
You can also hide the blade component in the Results browser
0 -
Thank you Prakash, is it possible to view only forces due to interaction between blades and bird and obscure centrifugal forces?
0 -
You can view contact forces as HG plot using TH/INTER
0 -
Thank you, and how can i make a rotational system of reference integral to blades to view the displacement?
0 -
I don't understand why this centrifugal forces are so hight, Are correct use rigids (rbody) to connect blade at the centre ? there is another way to model the joint between blades anda case ?
0 -
HI,
There are two methods to correctly account for the centrifugal force. The first method would be to use an imposed velocity starting at zero and increase the speed to the final value. I would recommend using a smooth curve
The second method is to do the preload using /LOAD/CENTRI. Included are example files.
With either method you can use *.sta state files to save the preload in the blades and reuse it in other simulations assuming you do not change the rotating blades between simulations
0 -
thank you Prakash, in last model i use ' initial velocity around an axis' is this wrong ? now i do as you say but i'm a starter with radioss and i can't do it. if i send you the file with transfer link, Can you please help me to add imposed velocity ?
0 -
Yeah sure,
0 -
i send you the model. thanks a lot
0 -
Ok, thank you.
I will work on this as time allows.
0 -
thank you very much, Prakash.
