What is the use of cut plane and how to use that?
Cut Plane is used for visualizing the internal mesh of the model. The Cut Plane dialog can be opened by right-clicking on Model in the datatree and selecting Cut Plane. This option can be used only if the Visible entity is set to Mesh.
