I want to make a DOE of a contact distance(design variable) between two plates. The contact surfaces are represented by the interface of the blue and pink components (in the uploaded file). I want to create a parameter from the green fracture area to the beginning of the 2 blue areas. Finally, I want to observe the stress inside the plates according to this distance.
What would be the best way to create this design variable ?
Is it possible to create a parameter on the geometry ? Is there a way to generate a new mesh with the appropriate contact ?
Thank you,
Benjamin
