Print/add more model data in .out file
Altair Forum User
Altair Forum User
is it possible to add the center of gravity and mass moment of inertia as information to the .out file? In my .out file only volume and total mass fo the model are output.
Unfortunately - still after thorough checks - there is a mismatch between the volume and total mass which is computed via summary/moment of inertia template and the value in the .out file. That is why I expect a mismatch for the mass moment of inertia and center of gravity as well.
Kind regards
  • Altair Forum User
    Altair Forum User
    edited March 2017
    Hi @msc
    Are you running any optimization problem?
    If yes, can you change the MATINIT to 1 from Optimization>> OptiControl and compare the mass and volume.
    By default the material fraction used at zeroth iteration is not 100% and one can change this to 100% through MATINIT.
