is it possible to give a solid a defined eigenfrequenzy. The Problem is i had to do a modal Analysis of a satellite structure and the first eigenmode had to be above 40Hz, but my tank had a eigenmode at 30Hz. But i know that the frequqnzy of the real tank is 45Hz. So can i give the solid a eigenfrequency with 45Hz?
Thanks for your help
