Hello everyone, my name is Fernando, i want to ask you something about the tutorials that are inside flux software.
   	I have to do,  for my master degree research, a transient simualtion with a motor lineal with permanent magnets, and  i found two tutorials that maybe serve  to me learn, how can i do it,  the tutorials are:
   	1. Line Start permanent Magnet Machine
 	2. Linear Motor
   	and when i start  the tutorial number 1, after to set up the  parameters of the motor, and  gonna do the step for create the magnet, the tutorial tell:
 	 'Load the python file:”create_magnet.py”
 	(project >> command file >> execute in direct mode)'
   	The same thing happens with the tutorial 2, in the part where i have to create a circuit, th tutorial tells:
 	'Load the file: ‘Circuit.xcir'
   	Then the question is,  where are this files, because without them i can´t follow the tutorial.
 	I really appreciate, if someone can tell me where i can download them or if somebody has tutorials like those and can share to me. i  gonna be very gratefull.
   	thank you for all...
