How to give a concentrated(point) load on a moving body in radioss. The load is given perpendicular to moving direction of the body.
Hi Kamal Cahtanya,
Concentrated load can be applied using CLOAD in RADIOSS.
Go to Utility Browser>> Concentrated load.
Hi Kamal,
A concentrated load defines a concentrated force applied to each node of a prescribed nodal group. The load is applied to the nodes indirectly by means of a nodal group. The load versus time function is also defined to apply the CLOAD in RADIOSS..
