Mechanical Shock Test
1. I need to do an analysis by giving an acceleration of 20g (longitudinal) and 8g (transverse) for 50ms and similar for 65ms. How do i go about it. Can i do it on optistruct or Radioss.
2. Also i need to do a vibration test for the same component between 7 Hz and 50 Hz and back to 7 Hz traversed in 15 minutes. I have to do this for 12 cycles.
Thanks in advance.
You can use OptiStruct. Calculate the load for 20G and use it as FORCE.
Altair Forum User said:2. Also i need to do a vibration test for the same component between 7 Hz and 50 Hz and back to 7 Hz traversed in 15 minutes. I have to do this for 12 cycles.
You can use Frequency response subcase to model the same.
0 -
@Prakash Pagadala How do I do w.r.t time? I need to apply 20G for 5ms. Can I use the TSTEP card.
0 -
Hi @tintumat
Please check this tutorial OS-T: 1315 Modal Transient Dynamic Analysis of a Bracket
You need to use Transient response subcase if you want to provide time.
0 -
Hi @tintumat
@Prakash Pagadala how can i ask for acceleration and displacement as output as well. i did for displacement as shown in the tutorial.
my output reuqest is stated as so 'Acceleration exerted to the part to be measured with a minimum of 2 kHz bandwidth. (ACCELERATION)'
0 -
