Hello everbody,
could someboby help me? I want to analyze the hertzian pressure between a ball and plate. But there are some mistake (pictures below).
Thanks!!
Do you forgot to delete the 2D elements after 3D meshing?
How could I delete the 2D mesh after spinning?
Thanks!
after spinning?
Yes, after the rotation of the 2D Mesh
Hi
Even if your making a 3d elements using spin option, previously created 2d mesh creates a problem. To delete those press F2,elements by config and say quad4 elements or any type of other 2d elements and say delete.
Thanks
