Hi all,
How to create a complete analysis workflow in HyperMesh by using TCL codes? The workflow tree shows the complete process, like the following picture. I want to know how to create a GUI workflow tree like this. Thank you.
Roy
Hi
1) create a treectrl widget
2) create items for treectrl widget
3) write bound procs of the items
Can you do it?
Hi 1) create a treectrl widget 2) create items for treectrl widget 3) write bound procs of the items Can you do it?
Hello tinh,
Thank you for your reply. I don't know how to do this. Could you give me some simple example or reference documents?
Hi @Roy Duan
You can use Process Studio.
Thanks,
Imoto
Hi @Roy Duan You can use Process Studio. Thanks, Imoto
Hi Imoto,
Thank you for the vedio. How to output this workflow into hypermesh?
1.Save as .pmt file from Process Studio. 2.Stat the HyperMesh. 3.View(Pulldown) -> Process Manager. 4.Select .pmt file as Load template.<?xml version="1.0" encoding="UTF-8"?>
