Afternoon,
I am comparing the different types of lattice using a simple volfrac and compliance study with both a compression and bending load case.
- Lattice types 1 and 3 ran without problem.
- Lattice type 2 failed in stage 2 ever after deleting the line below ran without problems for both the bending and compression runs.
CONTACT 2 FREEZE 21 31OPENGAP NO
+ N2S SMALL NO NO .F
*** ERROR # 1479 *** in the input data:
Incorrectly formatted numeric data in field 7.
(If it is a character field, it should start with a letter.)
- Lattice type 4 failed with the same error however when I deleted the line below causing the error the model ran but generated a compliance of 0 for both the bending and compression runs.
I have attached both the start file, second stage file and output file for the bending study of lattice type 2 and 4. Can anyone help me with this issue?
Thanks in advance,
Tom
