Hello everyone,
Is there any way I can import an already meshed model (Abaqus/Optistruct) in MotionView?
Hi @vanguard478
Please use Tools menu>>Import FE or CAD option to import meshed model (HyperMesh file or OptiStruct file) in MotionView.
This will import the model as rigid bodies.
@Prakash I can't go with the geometry import because there are many components in the model. I was thinking of making systems for each of the assembly which have relative motions between them.
Also if I import the geometry, the CG coordinates would be hard-coded wrt to the global coordinates, same for the graphics files for each of the geometry, so if i have to position a system to another location on the model or if i have to use it multiple times with different orientation it would be really difficult.
