Optistruct- Optimizing and Analyzing
User: "Altair Forum User"
Updated by Altair Forum User
Is it possible in Optistruct to optimize a model and then afterwards analyze it for certain stresses? (run optimization and then run analysis on the optimized shape)
I have created a shape with certain forces and stresses and optimized it successfully for minimum compliance & constrained volume, but I would like to analyze the optimized shape for stresses in several different locations of the shape.
1 - 5 of 51
    OP
    1) What type of optimization have you used?
    2) what type of optimization are you planning ahead?
    You maynot get a desired result if you are using static stress in topology or free size optimization.
    OP
    I was using the topology optimization (in Hyperworks v12.0). I was using minimum compliance and a constraint on volume fraction. It was successful.
    Now I want to include static stress as a constaint.
    Is it advisable to set the problem as: minimize volume fraction and have a constraint on stress? I know there is an option to set a stress constraint in the topology section>parameters. Or is it better to set the static stess constraint as a response/constraint in the optimization section?
    Thanks for your help!
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Defining Stress constraint through DTPL card is recommended.PFA some FAQ on this topic.
    OP
    I used the stress constraint through the DPTL card as you mentioned.
    Thank you, it worked!!
    Thanks for the update..
