Hy,
I'm working at composite simulation and I need some help: I have to verify material card data give me by laboratory; with 0°/90° tensile test no problem but with +45°/-45° experimental curve and RADIOSS curve are totally different.
I try to eplain my problem better: material constants (by experimental Test) are E11= 20067 MPa, E22=23200 MPa, G12=1519 MPa, G23=1444 MPa and G31= 1444 MPa.
I have reproduced experimental test in RADIOSS and I have done card fitting. In 0°/90° tensile test curves were very different but after a little modification of elastic modulus, they fitt enought:
The problem is in +45°/-45° tensile test because curves are too different:
Radioss curves are made in Hyperview, protting strain and stress of an element.
What am I doing wrong? Could someone help me?
Thanks in advance.
