I am performing on sloshing inside a deformable fuel tank.
Do I have to define an interface between water and tank ? If yes, Do you please suggest card image for step ' create > set ' ?
When I would create 'contact' for water and tank, I should select card Image is ' Type 18' or ' Type 1' ? and there is any difference in final output ?
Thanks.
