Optistruct stores all iterations of optimization as standard.
It is possible to determine what is stored?
For example, if i would like to save only the initial, first and last iteration of the topology iteration.
Thank you
Hi @wan
Yes, Use DESIGN card and choose the option (example: DESIGN>> FL will output results for first and last iteration)
Go to Control cards>> OUTPUT>> DESIGN
