Someone knows why is giving me those errors?
Hi @anderlanza
this error is because law 28 honeycomb material is assigned to 2D elements, which is incompatible (see attached document).
Hi Ivan,
First of all, thank you for the respond .
In the image below I was putting the honeycomb material in 'espuma' and ' honey' and it was a BRICK, in which way I can change number of nodes?
As I have seen in the pdf that you have send me, if you have BRICK the only way to have compatibility is by having 8 nodes so what can i do?
The problem is you have SHELL3N (triangle 2D elements) in component which were assigned law 28 material.
Isolate the components assigned to law 28 material and mask solid elements, then delete the shell elements.
And how can i do that?
Sorry Im new in this program
Ok perfect thank very much!
Any idea of why is not showing me the result button?<?xml version="1.0" encoding="UTF-8"?>
Maybe there was no animation output frequency (ANIM/DT) defined.
Just find the folder with model files and open run_name.h3d file.
Was ANIM/DT file thank very much
Last thing any idea of how to do a rigid body of the bolt?
The thing is that i dont now how to select all this part<?xml version="1.0" encoding="UTF-8"?>
An another when it finishes the simulation why it does appear like this?
@anderlanza
Can you play the animation and check the results?
ok thank very much i have a problem with the bolts, that is that i cant make a rigid body in the hole of th bolt any idea<?xml version="1.0" encoding="UTF-8"?>?
As in this picture
