Dear all,
I am working on shaft mis alignment problem , there are two shaft and both are connected by using two coupler , i did the same analysis with using torsional spring,
Could you please any one suggest me how to give torsional spring , i have coupler stiffness just i need to replace coupler with torsional spring , my rotation axis is X direction,
