Hi
I want to do compression test of an composite material specimen (Solid cylinder diameter- 20mm, height 30mm) with specific composition as(weight percentage -Al-0.36, Zn 7.0, Mg 1.2, Cu 1.3, Zr 0.08, Fe 0.08, Si 0.06)
Please tell me the procedure to create composite material and its compression test. (Material initally formed by powder mrtallurgy)
Thanks.
