hi,
when i'm doing random vibration analysis i gave stress output in h3d form then mine is a 3d model how i see the stresses inside the model i.e elements other than surface elements
in hyperview it is showing the range from 1.421e-07 to 1.56e10 but i couldn't see that high stress elements there are abot 3 lakh elements in it how can i know the element of maximum stress in a range of frequencies?? if i give opti format it should print stesss 3 lakh element stress for each frequency step is it possible??
