HOW TO OVERCOME THIS ERROR??
I HAVE NOT USED ANY CBAR ELEMENTS.ONLY CBEAM ELEMENTS ARE USED HOW TO FIND CBAR 3729 AND CORECT THIS ERROR
Hi @SAJITH
Can you check if there are any CBAR elements you have created by mistake?
If yes and if they are not necessary, delete them and run again.
You can find CBAR elements using Shift+F5 (find entities)>> Elements>> By config>> Save found>> go to delete panel>> retrive and delete
