How do I get the curve points for bi-linear material property for doing crash analysis in Radioss from following data for my AISI 4130 material E- 210 GPa
UTS- 735 MPa
Yield- 604 MPa
Elongation in 50mm GL- 23.5%
You can use material law 2 (/MAT/LAW2 (PLAS_JOHNS) with these available data. Use Iflag=1 in this material law and provide these inputs.
Please go through Help Menu on this material law.
