How to carry out dynamic analysis of an entire assembly .
I want to analyse the entire wheel assembly as a whole and not knuckle and spindle differently with load varying with time .
Hi Umang,
What type of Dynamic analysis you are referring to?
You can do a Transient or frequency based analysis on assembly. There are tutorials available on the same in OptiStruct help, please go through the same.
Here are couple of similar studies:
http://www.altairatc.com/india/previous-events/2012/papers-2012/RL-04_Vibration_Analysis_of_2_Wheeler_Handle-Bar_Mahindra_2WH.pdf
http://www.altairatc.com/india/previous-events/2012/papers-2012/O-OS-11_To_Study_the_Dynamic_Behavior_of_Engine_L&TIES.pdf
Hi Umang, What type of Dynamic analysis you are referring to? You can do a Transient or frequency based analysis on assembly. There are tutorials available on the same in OptiStruct help, please go through the same. Here are couple of similar studies: http://www.altairatc.com/india/previous-events/2012/papers-2012/RL-04_Vibration_Analysis_of_2_Wheeler_Handle-Bar_Mahindra_2WH.pdf http://www.altairatc.com/india/previous-events/2012/papers-2012/O-OS-11_To_Study_the_Dynamic_Behavior_of_Engine_L&TIES.pdf
i want to analyse the entire suspension system of my prototype with proper joints then how can i add all the spherical , revolute ,etc joints to my components in hypermesh. also how to perform a crash test . tank you for youe time
You can use PBUSH elements to model joints and can include stiffness and damping for PBUSH elements.
Please note: if you are a commercial customer, you can contact your local support @ http://www.altairhyp...ortProduct.aspx
