i cant run the simulation using the tutorial in hyperworks 12.0 RD-3500.
I HAVE FOLLOW THE STEP IN THE TUTORIAL...AFTER A FEW TEST THAT I HAVE THE SAME ERROR STILL OCCUR.
CAN ANYBODY HELP ME....
Thanks for sending the model via dropbox again,
The model this time contains solid elements, you need to have a model with shell elements for the property prop/shellIf you intend to use a solid element model you will need prop/solidThis is the reason for the error.
while running the model, first go to file > export and in the export options select auto export engine filethen in the radioss panel click on save as and use the same name used while exporting in the above stepthen click on RADIOSS>
There are several crucial steps that you are missing in this analysis, see below - (you may have to follow the tutorial completely once)1) you must right click edit the component and give it a card image > part2) assign property and material to the component > right click on component > assign > property and material.3) there is no imposed velocity etc in the model only constraints so you must create an imposed velocity etc4)you must increase the run time
