Greetings, and thanks a lot for your help. I learn a lot from this community.
What I’m trying to do is modeling a drivetrain mount and the composite monocoque body and figuring out how drivetrain mount affects monocoque. The situation I want to simulate is when the car starting to move from stop how forces will go through mount to monocoque. And I’ve encountered some technical problems.
- I’ve done some analysis using NLEXPL and this would be a good choice of solver for this kind of analysis?
- The composite laminate should have 2 zones basically, with aluminum honeycomb or with gfrp insert and both of the skins are cfrp. This is how I tried modeling it. After the post processing, the gfrp part seems like falling apart from the laminate and I guess my way is not right. Any possible improvement for this?
- Using rbe element on the shell nodes on laminates does it affects to whole laminate thickness?
Thank you for your time.
.hm and .mvw files below for better explain
https://gofile.io/d/PBwxPb
