I have a 3D model (geometry) of multi- components that some of the its surfaces is defined as the boundary surfaces by new component (B_Surf). I use 3D page and tetra mesh or solid map option to mesh all components excluding B_Surf component. By using of the export item and Optistruct format, an output file from nodes coordinate and 3D elements information is obtained. How can I obtain information (nodes number) of the 2D elements created in the surface component (B_Surf) ?
Many thanks.
