A problem!
Altair Forum User
Submitted by a_a on Fri, 08/26/2011 - 20:43.
Most likely you have fixed plot bounds. In your plot block, bring up the properties dialog box, the first checkbox is 'Fixed Bounds'. It must be unchecked.
Another possible cause can be the simulation configured to run for 10 seconds. In the menu, go to System > System Properties and chnge the End value.
0 -
Submitted by ferdosinezhad on Sun, 08/28/2011 - 11:56.
You're the best! it was the latter case! Changed the end value and now it's working just fine. /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
