Hi,Is there a Radioss deformable barrier model for offset/side impact available to download like the one shown in this video (1:49:47) -
If not, where could I find the properties for this aluminum honeycomb material?Thanks,Arjun
Hi Arjun,
You can model a deformable barrier. I would suggest you check with suppliers for Aluminium honeycomb material properties.
Hi Prakash,
I have modeled the barrier, but for the Honeycomb (MAT28) material I have to input a total of 6 tensile and shear stress functions which I do not have access to.
I'm assuming these crash barriers are made from a standard (or at least similar) material. Is it possible to share the properties used in your training seminar I linked earlier?
Thanks,
Arjun
Hi jarjun,
I suggest google searching for relevant research papers and thesis.
You can find simplified material properties on page 29.
The tensile and shear stress functions can be found in
https://www.researchgate.net/publication/249505709_Characterization_of_Aluminum_Honeycomb_Material_Failure_in_Large_Deformation_Compression_Shear_and_Tearing
Hi Ivan, thanks a lot that is very helpful!
in this automotive webinar it is mentioned there is a safety database including dummies and barriers. How to access this content?
