' *** ERROR # 789 *** Invalid design properties w.r.t. the design variables were found. number of invalid property items = 5'
can u tell me what problem am facing???.
There is no zero values in lower bound and upper bound
Hi Mano,
Error message will not help us understand what you are doing,
Please provide more details about what analysis/optimization you are doing and what parameters are furnished.
if possible, please share the .out file.
@Prakash Pagadala Hi Prakash , Sorry for the late reply , here is my OUT file
Hi @mano112aprmw
Looks like moment of inertia is affected with the change in thickness.
Can you relax or remove PBAR#11 from design variables and check if that works?
