TCL and contact Error
Hi ,
Could someone tell me how to remove the errors of Penetration. I already used penetration tools.
ERROR ID : 612
Also I created the whole file using TCL script Could someone help me on How to implement contact between pulley and Rope as seen in the figure in it.
I donot know which command to use to select the top face elements of the pulley.
(In the TCL script it in the last line about contacts )
Hi Kartik,
I doubt whether Type 7 will work for this contact. You may have to try with Type 11 contact.
Please go through https://www.youtube.com/watch?v=mLGwVwYSmt4&t=56s&index=4&list=PLQ7KUGFuVz4u5y3SvIEIU07427-gATaG6 which is a webinar on RADIOSS and chapter 4 deals with contacts.
0 -
Hi
I saw the documentation and the video.
In the user guide it is mentioned it is applicable for 1D mesh
WIth support from the youtube video I have created the contact. But my contact is breaking . The simulation h3d file is attached. could you tell me what the problem is ?
thanking you,
yours sincerely,
kartik
0 -
Hi George P Johnson,
Thank you for your immediate reply. I can see you have defined 2 contacts.
I have a few queries below:
- How is the predefined initial stiffness of 5000 and its stiffness factor 0.8 assumed.
- Why the use of multiple contacts in the simulation? Isn't type 11 sufficient.
- Also is there anything else i.e modified?
yours sincerely,
kartik
0 -
HI,
Sorry, i forgot to change this. This simulation will work without STMIN and STFAC values. As a trial for the previous run I gave these values. Please remove it and run the analysis.
The edge to edge interface was not perfectly working and so Type 7 was also introduced with Type 11. No other changes were made,
