i just tried to do Analysis with Radioss and it showed me waring 312... so what is it about ? please someone explain it..thank you
hello,
i faced to similar warning when i fixed Die(which is part of my model) in Y-direction and gave the imposed load in Y-direction for the same part, so in my case i solved this warning by removing load in Y-direction. In the attachments you can check them.
so i recommend you to check your load collectors or share your file here.
Thank you.
Kind Regards,
Dipen Panchal
Hi
Warning ID 312 is because of an incompatible kinematic condition. Please recheck the BC's and load in the model
Check whether these previous forum posts on the same topics can help you.
