I'm having an issue with Optistruct: when running an Analysis Optistruct seems to finish it giving 'Job complete' but opening the .out file you can clearly see that analysis isn't complete.
I'll attach both the .out and .stat files
Thank you
P.S: the issue seems to disappear without the ASET load collector, could that be the cause?
