I'm trying to create a flexible body file by using Craig-Bampton Method. I need to write nodal stress values into the .h3d result file. From the global output request menu, I choose the stress option with corner location, then an ordinary analysis that has standard loadstep (for example linear static case) is run, and i can obtain the corner values. whereas, for the flexibody generation case, the nodal stress values are not written in the h3d file.
Is there any way to obtain corner stress values in a .h3d result file for a flexible body generation?
