checking the file before launching the analysis I found surface contact errors:
- WARNING # 4735 No contact element is created for CONTACT 1 at the start of analysis. SRCHDIS if the contact is not for finite / continuous-sliding (TRACK = FINITE / CONSLI) with large displacement analysis.
- WARNING # 4782 CONTACT interface 1 has 9128 Slave faces that belong to Master surface, indicating likely self-contact condition. Contact us.
- INFORMATION # 4739 The structure of surface-to-surface contact element is quite different than that of node-to-surface contact element. No internal CGAP / CGAPG elements are created for surface-to-surface contact.
- NOTES # 9199 MSGLMT = STRICT is active, all messages will be printed. MSGLMT = BRIEF or UNREF (in config file or in the input data).
Could anyone please provide or check how to rectify the error.
Thanks in advance.
