I need to design a part using topology optimization which has a first eigen frequency above 60 Hz.
I have created FE model with loads, SPCs. I would like to perorm topology optimization with minimize mass with displacement constraints and frequency constraint on 1st mode.
I have create the eigrl load case
My question is while creating the frequency load step should I include SPC's or not. Does it make much difference on the optimization result.
