Topology optimization of upright
Altair Forum User
Altair Forum User
I am running a topology optimization on a part, but I get the following error:
Load Steps are defined as linear static
  *** ERROR # 2148 ***
 Invalid design problem.
 All the sensitivities of response 2 (objective) are zero.
I am attaching the file, hoping that somebody can help me.
  • Altair Forum User
    Altair Forum User
    edited January 2018
    The problem setup is wrong.
    You are apply load on nodes where you constrained the same in all directions.
    Please check and update your constraints and loads.
  • Altair Forum User
    Altair Forum User
    edited January 2018
    Actually I want constraints on those nodes .....tell me is there anything I can do?
  • Altair Forum User
    Altair Forum User
    edited January 2018
    @Ripudaman
    Then your load application is wrong.
    You cannot apply load on the same node where you constrain the same in all directions.
    So please work on loads.
  • Altair Forum User
    Altair Forum User
    edited November 2020
    This time instead of giving constraints in all directions , I left one (Z- axis Rotational).But it still shows the same error :
    Here is the file :
  • Altair Forum User
    Altair Forum User
    edited January 2018
    And sir I am sure the loads applied are correct.
  • Altair Forum User
    Altair Forum User
    edited January 2018
    HI,
    You are telling the solver that the node should not move in any direction and at the same time you are applying force on same node. This is not valid.
    Please check in what directions you are applying the forces and what the constraints are.
  • Altair Forum User
    Altair Forum User
    Sir I changed my constraints and so there is no error now. But after running topology optimization ....it only showed one iteration 'Iteration zero'  and no more iterations. Here is the modal file.
  • Altair Forum User
    Altair Forum User
    edited February 2018
    I am not sure how you arrived at the loads and boundary conditions.
    But the loads coming from wishbone and steering makes sense, maybe you should think about the constraints. How about constraining at the wheel hub?
