Hello guys,
first of all, I'd like to thank you for your great support.
I'm quite new to FE analysis and now i'm facing my first problems.
To get known to HyperWorks, I started to mesh an imported CAD file with Hypermesh and defined materials and properties.
Before applying Boundary Conditions and forces I wanted to check the model for errors and started the anaylisis ( Solver: Radioss (Block 140))
That's where I encountered some error messages. With the help of this forum I was able to fix some problems.
For these messages I wasn't able to find any solution:
WARNING ID : 692
** WARNING IN SURFACE DEFINITION
WARNING ID : 690
** WARNING IN NODE GROUP DEFINITION
.. INITIAL VELOCITIES
ERROR ID : 668
** INPUT ERROR
DESCRIPTION :
-- /INIVEL ID : 1
-- /INIVEL TITLE : velocity
NO NODE GROUP DEFINED
ERROR ID : 53
** ERROR IN /INIVEL OPTION
DESCRIPTION :
-- NODE GROUP ID : 0
NODE GROUP DOES NOT EXIST
.. DOMAIN DECOMPOSITION
.. ELEMENT GROUPS
.. INTERFACES
ERROR ID : 119
** ERROR IN INTERFACE SURFACE DEFINITION
DESCRIPTION :
-- INTERFACE ID : 1
-- INTERFACE TITLE : contact
MASTER SURFACE IS EMPTY
ERROR ID : 119
DESCRIPTION :
-- INTERFACE ID : 1
.. RIGID WALLS
.. RETURNS TO DOMAIN DECOMPOSITION FOR OPTIMIZATION
.. ELEMENT GROUPS
.. INTERFACES
ERROR ID : 119
DESCRIPTION :
-- INTERFACE ID : 1
ERROR ID : 119
DESCRIPTION :
-- INTERFACE ID : 1
.. RIGID WALLS
.. ELEMENT BUFFER INITIALIZATION
WARNING ID : 312
** INCOMPATIBLE KINEMATIC CONDITIONS IN MODEL
DESCRIPTION :
271519 INCOMPATIBLE KINEMATIC CONDITIONS IN MODEL
.. GEOMETRY PLOT FILE
.. ERROR ==> NO RESTART FILE
ERROR TERMINATION
6 ERROR(S)
6 WARNING(S)
PLEASE CHECK LISTING FILE FOR FURTHER DETAILS
